Battery settings not performing as expected
Dylan Chen 5 Reputation points
2026-01-13T19:27:09.4566667+00:00
Surface 6 laptop with Windows 11. The main issue is with battery management when the computer is unplugged. What I'm expecting to happen is that I can configure the setting so I can close the lid without performing a full shutdown and have the battery last longer than an evening.
My understanding is that this can be achieved by configuring the unplugged battery setting for the "close lid" action to operate in "hibernation mode". Hibernate mode is defined as using less power than sleep, and when you start up the PC again, you’re back to where you left off (though not as fast as sleep). Use hibernation when you know that you won't use your laptop or tablet for an extended period and won't have an opportunity to charge the battery during that time.
Current situation. Regardless of what I configure, the unplugged battery settings too, my laptop battery will completely drain overnight. I had an older laptop that would survive for several days in a hibernation state, and I'm expecting the same for this laptop and can't seem to make it happen.
Surface | Surface Laptop | Power and battery
  1. Dylan Chen 5 Reputation points
    2026-02-09T16:53:55.4833333+00:00
    Hi Thomas
    Thanks for the follow-up.
    I couldn't get the powercfg /batteryreport to work, but I'm not sure if that's a limitation from the business account through my employer. Is that battery report the same as the "battery usage" chart in the power settings?
    So far, the biggest help has come from your comment regarding disconnecting everything before closing the lid. If I disconnect everything (especially the power supply) and let it operate for a minute or so before closing the lid, the battery has lasted, and sleep mode has worked. Seems like it's just a change to the workflow I've been used to from older models.
  2. Thomas4-N 16,945 Reputation points Microsoft External Staff Moderator
    2026-02-01T10:02:14.0466667+00:00
    Hello Dylan Chen, welcome to Microsoft Q&A forum.
    On modern Surface laptops running Windows 11, closing the lid does not fully power the device off. These systems use Modern Standby (S0 low‑power idle) instead of the older S3 sleep model. That means the device may briefly wake in the background for maintenance tasks or drivers, even when the lid is closed.
    A small battery drop overnight can be normal, but draining most or all of the battery by morning is not expected. That usually means the device isn’t reaching a deep idle state and is being woken repeatedly.
    Here are a few things worth checking:
    • Make sure Windows and Surface firmware are fully up to date through Windows Update and the Surface app. Firmware issues are a common cause.
    • Disconnect everything before closing the lid, including USB‑C hubs, monitors, dongles, or receivers, as these can keep the system awake.
    • Review background app permissions and set anything non‑essential to Power optimized or Never run in background.
    • Enable Battery Saver to further reduce background activity while on battery.
    • Generate a battery report to confirm what’s happening overnight. Open an elevated PowerShell window and run: powercfg /batteryreport Then review the report to see battery usage while the lid was closed.
    If you need the battery to last for multiple days without charging, a full shutdown is currently the most reliable option on Modern Standby devices.
    2026-01-13T19:27:20.1133333+00:00
    To address the issue with your Surface 6 laptop's battery management when unplugged, it's important to ensure that the settings for the lid close action are correctly configured. You can set the action to "Hibernate" when the lid is closed, which should help in conserving battery life compared to sleep mode. Hibernate saves your session to the hard disk and completely powers off the device, which should allow for longer battery life when not in use.
    However, if your laptop is still draining the battery overnight despite these settings, there may be a few factors to consider:
    1. Adaptive Hibernate: Ensure that adaptive hibernate is enabled, as it allows the system to hibernate dynamically based on battery drain, potentially improving battery management.
    2. Background Processes: Check if there are any applications or processes running in the background that may be preventing the laptop from entering hibernate mode effectively.
    3. Power Settings: Double-check the power settings in Windows to ensure that they are configured correctly for both plugged-in and unplugged states. You may want to review the battery level settings for when Energy Saver activates as well.
    4. Firmware and Drivers: Ensure that your device's firmware and drivers are up to date, as updates can improve power management features.
    If these steps do not resolve the issue, you may want to consider reaching out to Microsoft support for further assistance, as there could be specific hardware or software issues affecting your device's performance.
