Permanently disable Surface pro smart charging
Lee, Hanshin 10 Reputation points
2026-01-28T00:29:57.1533333+00:00
I would like to permanently disable the smart charging on my Surface Pro.
I know it is currently not possible to do so.
I very strongly suggest that Microsoft to soon release an update for the Surface app so that Smart charging is "opt in" instead of "opt out".
Please appreciate the fact that the users are more intelligent that what you think and let them decide what is needed for themselves.
Thanks,
Surface | Surface Pro | Power and battery
  1. S.Sengupta 30,891 Reputation points MVP Volunteer Moderator
    2026-01-28T01:29:32.07+00:00
    • You're right that Smart Charging can't be permanently disabled at this time. This feature is intended to prolong battery life by restricting charging when your device remains plugged in for extended periods. While the Surface app lets you temporarily disable Smart Charging, there's no option to turn it off permanently.
    • You can pause Smart Charging, open the Surface app when the feature is active. Kindly follow the instructions as sited here: Smart charging on Surface
    • You can share feedback with Microsoft through the Surface app by navigating to Settings and selecting Give feedback. This ensures your input reaches the product team directly.
