Hello again Ahmed Nabil,
I am following up to see if you have managed to resolve the version incompatibility between your Power BI Report Server and the Desktop client. To summarize the previous technical advisory, Microsoft does not maintain a public archive for deprecated PBIRS Desktop versions, meaning the January 2024 installer is no longer obtainable through official channels. The most robust "best practice" solution is to perform an in-place upgrade of your Power BI Report Server to the latest version, which will immediately render it compatible with the modern Desktop clients your users are likely already downloading.
If an immediate server-side upgrade is not feasible during this window, your only secure option is to retrieve the specific installer file (PBIDesktopSetupRS_x64.exe, version 2.124.1960.0) from your organization's internal backups or the original SQL Server Enterprise ISO media obtained via the Volume Licensing Service Center (VLSC). Relying on the server upgrade is strongly recommended to ensure long-term supportability and security compliance.
If the issue has been successfully resolved, please consider accepting the answer as it helps other people sharing the same question benefit too. Thank you!
VP
