How to fix a Surface Laptop 7 Battery Not Charging
Wendy McConnell 0 Reputation points
2026-02-16T19:41:24.2633333+00:00
I have a fairly new Surface Laptop 7 with a battery that does not charge. I'm using the power source that came with the device, but it is not charging. It shows the battery at 0% with the lightning bolt. Any help?
Surface | Surface Laptop | Power and battery
  1. S.Sengupta 30,891 Reputation points MVP Volunteer Moderator
    2026-02-16T23:54:42.9633333+00:00
    Does the charger LED light up?
    Hold Power button for 20–30 seconds
    Release
    Wait 10 seconds
    Turn it back on
    If it boots → check if charging improves.
    Shut down completely
    Hold Volume Up
    Press and release Power
    Keep holding Volume Up until UEFI appears
    If battery still shows 0% in UEFI, that strongly suggests:
    Battery firmware issue or defective battery.
    If:
    Battery stuck at 0%
    UEFI shows 0%
    Hard reset doesn’t fix
    This is likely a warranty replacement case.
    Surface Laptop 7 batteries are not user-replaceable, so Microsoft support is the correct path.
    2026-02-16T19:41:38.12+00:00
    If your Surface Laptop 7 is not charging, here are some steps you can take to troubleshoot the issue:
    1. Check the Power Supply: Ensure that you are using the original power supply that came with your Surface Laptop 7. Verify that the power supply is plugged into a working outlet.
    2. Inspect the Charging Port: Look for any debris or damage in the charging port of your laptop. Clean it gently if necessary.
    3. Run the Surface Diagnostic Toolkit (SDT):
      • Connect the power supply to your device.
      • Boot the device to the Windows Desktop.
      • Use Windows Explorer to navigate to the USB drive containing the SDT executable and launch it.
      • Select Repair from the drop-down menu, then choose Repair Setup and Validation. Run the Battery Repair (Setup) to put your device into repair mode. Follow the on-screen instructions.
    4. Battery Authentication: After running the Battery Repair, you should also run the Battery Repair (Validation) tool from the SDT to ensure the battery is properly authenticated. This requires a stable internet connection.
    5. Allow the Battery to Charge: With the device connected to the power supply, let it charge until the battery icon in Windows shows at least 50% remaining charge.
    If these steps do not resolve the issue, consider reaching out to Microsoft Support for further assistance.
