Run Surface Diagnostic Toolkit
Fix common problems using the Surface app and Surface Diagnostic Toolkit
Open Device Manager
Look for:
Yellow exclamation marks
Unknown devices
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
I have tried holding power down for 20 seconds to restart as well as the surface toolkit might be missing right driver
Open Device Manager
Look for:
Unknown devices
AI answer
If your Surface Pro is not holding a charge but the battery light shows, it could indicate a few potential issues. Here are some steps you can take to troubleshoot:
These steps should help you diagnose and potentially resolve the issue with your Surface Pro not holding a charge.
