To record video and audio on a Surface Pro 6 and then save/edit it, use the built-in Camera app for video and the Voice Recorder or Clipchamp apps for audio/video editing.
- Record a video with camera and sound
- Open the Camera app (select Start, then Camera).
- By default it is in photo mode; switch to Video mode.
- Press the Video (camera) button to start recording; press again to stop.
- A small privacy light appears near the active camera when it is in use.
- Videos are saved automatically; use the Photos app or File Explorer (in the Pictures / Camera Roll folder) to find and open them.
If there is no sound in the video, check the default input device:
- Go to Start > Settings > System > Sound.
- Under Input, select the built-in mic (or the mic you want to use). Selecting it sets it as the default recording device.
- Record audio only
- Open the Voice Recorder app:
- Go to Start, select All apps, then select Voice Recorder.
- Use the record button to start/stop audio recording. Files are saved automatically in the app.
- Check sound output and input devices
If playback or recording is not working:
- Under Output, choose the speakers/headset to use for playback.
- Under Input, choose the microphone to use for recording.
For communication apps (like Skype), set communication devices separately:
- In Settings > System > Sound, select More sound settings.
- On the Playback tab, select the device and choose Set Default Communication Device.
- On the Recording tab, select the mic and choose Set Default Communication Device.
- Record webcam video and edit it in Clipchamp
To record and then edit a webcam video (with audio):
- Open Clipchamp (desktop app on Windows or go to app.clipchamp.com in Edge/Chrome).
- Create a new project.
- Select the record & create tab, then choose the camera option.
- Record the webcam video (it uses the selected camera and microphone).
- After recording, the clip appears in the editor where it can be trimmed, edited, and exported.
- Record screen + audio (if needed)
If the goal is to record the screen with audio:
- In Clipchamp, select record & create and choose screen or screen and camera.
- Select the screen/window/tab to record and whether to include system audio.
- Start recording; the microphone and system audio will be captured.
- Select stop sharing to end the recording, then save and edit.
- A WebM file is downloaded (usually to the Downloads folder) and also added to the Clipchamp timeline for editing.
If recording still fails (no video, no audio, or cannot save/edit), verify:
- The camera is not blocked or turned off by a physical shutter or function key.
- The correct microphone and camera are selected in the app (Camera or Clipchamp).
