Using older versions of Outlook for Mac in business environments
Thank you for sharing your concern.
Firstly, I’d like to clarify that this is a user-to-user support forum, and we are not Microsoft Support. Moderators participating here do not have access to backend systems, nor can we directly intervene in Microsoft product functionality. Our role is limited to providing technical guidance and sharing best‑practice recommendations based on reported issues, user requests, and common scenarios.
To ensure I fully understand your situation and provide the most effective assistance, I’ll need a few additional details, such as:
What is the current account type configured in your legacy Outlook (IMAP/POP or Exchange)?
Is your business email acccount hosted and managed on Exchange Online, on-premises, or directly through GoDaddy?
Based on your description, looks like this issue is related to how the email account is configured rather than a synchronization issue within Outlook itself. As far as I know, Outlook can only synchronize contacts between devices when the account is connected to a service that supports full data synchronization, such as Microsoft Exchange or Microsoft 365.
Reference: Sync basics - what you can and cannot sync - Microsoft Support
If the GoDaddy email account is configured using IMAP or POP, only email will synchronize. Contacts are stored locally on each computer and will not sync between devices.
To resolve this, you could consider to verify with GoDaddy whether your email accounts are hosted on Microsoft 365/Exchange. If they are, please re-add the account in Outlook using the Exchange or Microsoft 365 option instead of IMAP/POP. This ensures contacts are stored in the mailbox and will synchronize automatically across both computers.
If your contacts were previously created in a local “On My Computer” folder, you may need to export them and then import them into the Exchange-based contacts folder so they can begin syncing.
You can refer via: Import and export email, contacts, and calendar in Outlook for Mac - Microsoft Support
If GoDaddy is only providing IMAP/POP email (without Exchange / Microsoft 365), then Outlook will not be able to synchronize contacts between desktops, as this is a limitation of the protocol.
I hope this helps.
Please understand that our initial reply may not always immediately resolve the issue. However, with your help and more detailed information, we can work together to find a solution.
