I don't think the "Fast Startup" is the reasonreason.Factly,i got the same problem when i turn off my XiaoMi laptop night(battrry100%),in morning the battery 70%,but not 100.I still don't solve this problem,but if you want to check if that's the culpri,you can open the control panel then find the power,there will be a button"change power seeting",then open it,there will be a "fast startup",you can turn it off.
If you turn"fast startup"off,the problem are not be solved,i think this problem might be the hardware problem.
