Other issues or features related to Microsoft Edge on Windows 11
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
I wasn't experiencing this problem until yesterday. However, since this morning, whenever I launch Microsoft Edge, all of my previously saved tab groups appear to be gone. As a result, I have to reopen the tabs and recreate the groups every time.
I've already verified that the "Open tabs from the previous session" setting is enabled, but the issue still persists.
I can understand how inconvenient this is, especially if you use tab groups to keep several tasks organized.
A few questions that may help narrow this down:
In the meantime, please try the following:
edge://settings/help and make sure Microsoft Edge is fully updated, then restart the browser.edge://settings/privacy/clearBrowsingData/clearOnClose If anything related to browsing data is enabled there, temporarily turn it off and test again.edge://settings/profiles/sync and make sure sync is enabled. If you see an option for Workspaces and Tab Groups, turn it on as well.edge://extensions/, especially any tab manager, session manager, privacy, or cleanup extensions. Then create a small test tab group, close Edge normally, and reopen it.edge://settings/profiles and selecting Add profile. Create a few test tabs and a tab group there, then close and reopen Edge. While my initial response may not fully resolve the issue, I truly appreciate your cooperation as we work together toward identifying the most effective solution. Thank you so much for your understanding.
AI answer
Edge restores the last open tabs (including tab groups) only when they belong to the same profile and session, and when startup and data‑clearing settings allow it.
To keep tab groups after closing Edge, verify these settings and conditions:
If a different profile was created or used recently, switch back to the original profile and the tab groups should be restored when Open tabs from the previous session is enabled.
