oil & gas industry - iot sensors
Mushahid Abbasi 1 Reputation point
2022-01-03T04:50:33.567+00:00
Hope you are doing well. I want to use Azure iot sensors in oil & gas industry for use-cases like remote site monitoring. I would like to know :-
  1. What type of sensors are available for this use-case?
  2. How many sensors will be required?
  3. How much area they can cover for monitoring?
  4. Pricing
Thanks & Regards,
Azure Internet of Things
  1. AshokPeddakotla-MSFT 36,021 Reputation points Moderator
    2022-01-03T11:49:33.683+00:00
    @Mushahid Abbasi Welcome to Microsoft Q&A forum! Thanks for your interest in Azure IoT. It would be great if you can elaborate your queries with more details to understand better and provide suggestions accordingly.
    However, please find the below answers to your queries.
    For new IoT solutions and applications, our Azure Device Catalog currently offers hundreds of IoT Plug and Play-enabled certified devices. These devices can be easily connected to Azure IoT services such as Azure IoT, Azure IoT Hub, and Azure IoT Central.
    The vast majority of the world’s industrial IoT projects are targeted towards existing assets and environments with a myriad IoT-capable sensors and devices that are already in use. For this reason, we are further expanding the use of IoT Plug and Play technology to these scenarios.
    How many sensors will be required? & How much area they can cover for monitoring?
    This information is completely depends on your requirement. Based on the length, breadth and height of the area you need to choose the devices.
    Also, each device has its own hardware capabilities and specifications.
    For Ex: If you choose smoke alarm sensor from the Device Catalog, it shows the hardware specifications and other required information.
    Pricing
    Price may vary depends on the type of sensors/devices and the country of availability and delivery. When you click on purchase you will be redirected to the
    Please check Learn more about Azure IoT for your industry, Azure for the energy industry and Fueling the oil and gas industry with IoT customer stories for more details.
    Do let us know if you have any further queries.
    If an answer is helpful, please click on 130616-image.png or upvote 130671-image.png which might help other community members reading this thread.
    3 people found this answer helpful.
  2. MUHAMMAD IBRAHIM HUSSAIN 0 Reputation points
    2026-06-13T02:25:15.5466667+00:00
    Accept answer
