To clean the print head, you don't do this via Windows. You need to donwload and install the Epson Smart Panel app onto your phone. Then set up the printer in the app, you will then find the "print head cleaning" option to do so.
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
How to I find the Printer Driver window in order to power clean the print heads of my Epson XP 2205 printer
AI answer
Use the Epson printer’s own software or control panel; the Windows “Printer Driver window” itself does not provide a special “power clean” option.
To get to the printer’s driver settings in Windows 11:
In the Printing preferences window, check for a Maintenance, Utility, or similar tab/button. From there, run Clean printhead, Align printhead, or other maintenance tools provided by Epson. If a specific “power clean” option exists for this model, it will be exposed in that Epson maintenance/utility section, not in generic Windows controls.
If the maintenance tools are missing, update or reinstall the printer driver so the full Epson utility is available:
